Sony 42W700B vs Samsung 40 H6400
kul
ghaziabad
HI guys,
I am looking forward to buy a new led TV very soon.
comparing Sony and Samsung models.
i kind of zeroed down to these 2 models. and both at available at same price.
so now i need the comments from the experts on which TV will be a best buy.
considering that we can ignore 2 inches of Sony and 3d features of Samsung (consider them as add-on and not the main criteria for comparison).
i saw both the TVs in their exclusive show rooms, and also together at reliance.and could not differentiate much.
so the confusion still remains, as which one should i go for.
thanks in advance.
^ Believe your eyes, if you didn't find any diff between two then you should look for next imp thing is about extended warranty, its cost difference in both.
Even I too find both are having very good PQ during my recent visit.
After satisfying in both above (PQ & warranty) then finally add that 2" of sony or 3D of samsung. I think in samsung you may get camera as festival offer which then can be used as motion control which sony doesnt has it.
The best is to decide which one offers better picture, connectivity and performance and meets your requirements and budget.....this means a side by side comparison in a electronics shop if possible and look at the screen from all angles...remember the shop's lighting and your home lighting is different.....check the sound output quality and see if there is ample connectivity thru component, analog and HDMI.......if something fails in future atleast you have some other connectivity backup to continue viewing ...all the best. Warranty plays an important role.
