It is a toss between larger size/lower quality (55HX750) vs. lower size/stunning quality (46HX850). Both have pros and cons. Do a demo and then decide.Thanks for your views and suggestions.
Since mine is bright room the option of Plasma is ruled out.
My First choice was for Sony HX850 46". But since few of my freinds and relatives suggest to go for 55" i thought of HX750 or Samsung ES6200(thoug both are lower level 3D Led TV).
Since i have to use the TV for normal SD channels and HD also prefer TV over Projector(also being a bright room).
Had few reviews of both. But could not find any major difference. Also Sony has 3D galsses which is of considerable weight and also cost three times the Samsungs.
But now am in confusion over both. Hope could finalise either of both this weekend.
regards
Thanks for your reply
I had demo of both HX850 and HX 750. I agree that HX850 has Stunning PQ as compared to HX 750.
But felt that HX750 does not fall so behind. offcourse the black level was clearly the major difference.
My viewing distance would be between 12' to 15'. Mainly would be DHT in weekdays and may be for BD movies in weekends.
hows ur opinion on Samsung ES6200 as compared to HX750??
regards
Congrats! enjoy your purchase,good that you choose 55" cause i always feel bigger the better, i gotta get my hands on one of those 64" plasma in the near future.
