sony's first 5.2 AV Receiver
simplysam.singh
New Delhi
Hii all,
When i was searching for AV receiver in crutchfiled, I found that sony launched its first 5.2 ch AV receiver in USA:yahoo:and i found that its having good review in many other sites too. Pls. find below the complete specs with some pics
Amplifier/Receiver Amplifier Features
4 Ohm/8 Ohm Switching : Yes (6 ohm)
Sub Woofer X' Over : 17 points (40 - 200 Hz)
Number of Amp channels : 5 channels
Speaker Impedance : 6-16 Ohms
Advanced Auto Volume : Yes
OP processing : Yes
Night Mode : Yes
Speaker Terminal : Screw
Speaker Selector : A / Off
Amplifier/Receiver Amplifier Power
(6Ohms, 1kHz, 2ch driven) THD : 1%
(6Ohms, 1kHz, 1ch driven) THD : 0.9%
6ohms, 20-20kHz, 2ch driven : 90 W + 90 W / (0.09%)
6Ohms, 1kHz, 2ch driven : 105 W + 105 W
6Ohms, 1kHz, 1ch driven : 145 W
Amplifier/Receiver DCAC Features
Mic : Mono
Band : 6
DCAC : D.C.A.C.
Amplifier/Receiver Input/Output Others
MHL (Mobile High-definition Link) Front/Rear : 1 Rear Input Supported MHL version Incorporates MHL 2 Maximum current 900 mA
Audio Features
Audio Features Decoding Format
Dolby Digital EX/ Dolby Digital : Yes/Yes
Dolby TruHD/Dolby Digital + : Yes/Yes
DTS HD MA/ DTS HD HR : Yes/Yes
Dolby Prologic/II /IIx /IIz : Yes (Prologic, Prologic II)
DTS 96/24/ DTS Neo:6 : Yes (DTS 96/24)
Dolby Dual Mono : Yes
DTS / DTS-ES (Matrix6.1 / Discrete6.1) : Yes/Yes
LPCM (2CH/5.1CH/7.1CH) thru HDMI : Yes/Yes
Audio Features Sound Field
PLII Movie : Yes
PLIIx Movie : Yes
PLII Music : Yes
Portable Audio Enhancer : Yes
Stadium : Yes
Sports : Yes
Sound Field Link : Yes
Live Concert : Yes
Multi Stereo : Yes
Neo:6 Music : Yes
Neo:6 Cinema : Yes
A.F.D. Auto : Yes
Pure Direct : Yes
HD-D.C.S. : Yes
Analog Direct : Yes
Hall (large hall) : Yes
Headphone 2ch : Yes
Headphone Direct : Yes
Jazz Club : Yes
2ch : Yes
Audio Features Tuner
Preset Channel (FM/AM) : 30 FM, 30 AM
Station Name : Yes
Direct Tuning : Yes (OSD)
Auto Tuning : Yes (OSD)
General
General Other
Power Requirement : 120 V 60 Hz
Power Consumption (Power Stand By) : 0.3 W
Power Consumption : 200 W
Pin Jack : Nickel
Sleep Timer : Yes (up to 2 hours)
Auto Standby : Yes
Display : 10 digit dot matrix
Digital Input Assign : Yes
iPod Browsing with System (via USB) : USB works with: iPhone 5s, iPhone 5c, iPhone 5, iPhone 4s, iPhone 4, iPhone 3GS, iPhone 3G, iPod touch (2nd through 5th generation), iPod classic, and iPod nano (3rd through 7th generation).
Inputs and Outputs
Inputs and Outputs Audio Inputs
Analog Audio In : 4
Coaxial : 1
Optical In : 2
Inputs and Outputs Audio Outputs
Pre Out (Subwoofer) : 2
Headphone Out : Yes (Gold)
Inputs and Outputs Other Inputs and
USB : Supported formats: MP3 (MPEG 1 Audio Layer-3): 32 kbps 320 kbps, VBR WMA: 48 kbps 192 kbps AAC: 48 kbps 320 kbps WAV: 8 kHz 48 kHz, 16 bit PCM
Inputs and Outputs Speaker Outputs
Center : Yes
Front A (L/R) : Yes
Surround (L/R) : Yes
Inputs and Outputs Video Inputs
AV In: Including Front AV : 2
HDMI In : 4
Inputs and Outputs Video Outputs
Composite Video Out: Inc. Monitor Out : 1
HDMI Out : 1
Video Features
Video Features A/V Sync Features
A/V Sync Sampling Frequency : 48 kHz --------------CONFIRM-------------------
A/V Sync Time (msec) : 60 msec
A/V SYNC : Yes (Fixed)
HDMI video output capability : 4K, 1080p, 1080/24p Deep Color (up to 36 bit) Triluminos Color (xvYCC)
Power Off Pass Through : Yes
3D over HDMI : Yes
BRAVIA SYNC (CEC Control) : Yes: One-Touch Play, System Audio Control, System Power Off
Audio Return Channel : Yes
Audio Widget : Yes
