deepakjeswal
Hi Friends,
I purchased a Denon DP300F Turntable via Amazon and it arrived on Wednesday. I replaced the standard issue cartridge with an Ortofon 2M Red. The turntable worked fine till Saturday evening, and I switched it off as usual and slept. I am using the built in phono Pre-amp.
On waking on Sunday, it suddenly developed strange problem:
a). One channel stopped working i.e. no sound coming out of one channel
b). As soon as the tone arm goes over the platter, there is a huge buzz / hum from all channels, including the sub-woofer. This is there if I simply rotate the platter now.
Things I have already checked:
1. My amp (also, a Denon) is fine. I checked with other sources - both channels are working there
2. I swapped the cables to the amp (red/white swap), and the sound went on to the other channel. (i.e. first it was coming only from left, and on swap, only from right).
3. I moved the Turntable away from the usual place and plugged it in another socket - same two issue persists.
4. I changed back the cartridge to the original one (though I really doubted that was the issue) - and goodness, what a tough exercise that is! Same two above issues continue
5. I switched off the built in preamp switch in the turntable - the sound obviously was low - but again it was coming from one channel only. And the above two issues continue.
I don't know if the two above listed issues are interlinked but I guess so since they developed together. Even now, if I remove the headshell and just hover the tonearm over the platter, and as soon as it starts to rotate, the loud hum / buzz / subwoofer starts off. I just have to mildly rotate the platter manually and the buzz / hum is there.
I am at my wits end, and I have read all I could but can't find any solution other than that the Denon has gone wrong. Since the audio cables are fixed in Denon inside the machine, I can't change the Red/White wires to check.
Is there any help?
Is there any decent service centre in Mumbai where I can consult on this?? ( Google throws me up a Denon Centre in Kandivali / Santa Cruz, but I am not sure if they will know about Turntables).
I am in a fix, I am sad and angry and really don't know what to do - I had bought this after using the ultra-basic Denon 200USB for 10 Years. Never thought a Denon will go kaput so soon ( I also have two Denon amplifiers working superb, so my trust on the brand is good).
PLEASE HELP me with a contact who can actually repair and set this right.
Is there any help?
