Sound Card under 5 K. for movies.
vinsks
Delhi
Hello Friends,
i am in search of a sound card (should have 6 channel analog output for 5.1 sound) for my PC.
Budget : under 5 k
mainly used for movie watching.
Please suggest me something good as i am confuse here. and is not able to come to any conclusion.
regards
Vinay Singh
Look for Asus Xonar series sound cards. They have got great reviews.
thanks brother,
priviously i was thinking of asus xonar dx... first there is availability issue another i have read that is card have some driver compatibility issue. not sure how much truth in that.
however still i have eye on asus xonar dx. but looking if i can found something better within my budget.
more suggestions are welcome :p ;)
regards
vinay singh
Asus Xonar DX 7.1 will come in your budget and is the best bang for buck. But if you can raise your budget a bit, you can't go wrong with Asus Xonar D2X
good info, if you can raise your budget a bit, you can't go wrong with Asus Xonar D2X ,thanks
hello Friends,
thanks for your response,
sorry for the late reply, just bit buzy with diwali.
Happy Diwali to you all...
yes Asus Xonar D2x is bit out of budget for now.
However regarding Asus Xonar DX, does it still have driver issue. or diver issue is resolved now. please share you view.
regards
vinay singh
There are no driver issues. I use the ones from Daniel K, zero issues! Go for it, nothing beats the DX in this price range.
hello Friends,
regards
vinay singh
thanks Rockfella,
thanks for you suggestion.
this is now in my concideration now.
regards
vinay singh
Xonar DX has no sound related issues. I am currently using it in my setup with DA Pro.
Maybe the interface doesnt allow for volume control sometimes. But last time I installed driver (Before format) that was working.
I would suggest matching DAC with speakers. What are your speakers? For DA Pro it is over-match.
Regards.
Regards.
Hello Humblebee,
i am preferring it with DA5000 pro only, for movie only
however also have NAD326 BE + PSB Image B5(for music purpose only), so i have option to connect these in place of Front Speakers
regards
vinay
Hello Friends,
Budget : under 5 k
regards
Vinay Singh
Have a look at 'Asus Xonar U7' it costs 5.5k and it's available here ......
Asus Sound Card Xonar U7 - www.deltapage.com
Cheer.:clapping::clapping::clapping:
You don't have to spend 5k on DX, just get a DG and DA 5000 Pro and you will be set.
Hello Humblebee,
regards
vinay
