Sound For my HTPC
vickysami
Hi All,
ASUS Mobo - M2NPV-VM
Point Of View - Geforce GT440 1GB DDR3
Cooler Master Elite 360
Dynet 1GB DDR2 ( will upgrade if i cant play bluray rip movies )
Onkyo - HTS 5100
there are 2 things i can do to get DD / DTS for my HTPC to AVR.
PPA International 1431V 6 Channels 16-bit PCI Sound Card Retail
http://cgi.ebay.in/ws/eBayISAPI.dll?ViewItem&item=270891619878&ssPageName=ADME:X:RTQ:IN:1123
Got this reply from Ebay seller what does this mean ?? :
As per the listing The PPA International 1431V PCI 6 Channel Sound Card is 32 bit PCI bus master, PCI 2.1 / PCI 2.2 compliant. It supports front left-right, rear left-right surround sound. Center and subwoofer (low frequency effects) 6 channel audio out.However if you require more information please log into the manufactures website.All electronic/electrical items sold by Cart2india Online are originally meant for use in the USA (110 volt AC input). For usage in India, a step down converter should be used in order to bring down the voltage from 220/240V to 110V. We will not be liable for any electrical damages, failures, loss of performance of such products and/or their accessories. Laptops, Mobile phones, Tablet PC (iPad, Kindle etc) come with a universal 110v-220v charger that can be used worldwide.
Second one is:
SPDIF RCA Out Plate Cable Bracket
SPDIF RCA Out Plate Cable Bracket | eBay
Which one to buy ??
like i have asked this before but just want to confirm before buying it from ebay.
If i use a spdif header braket, it can pass DD / DTS to my receiver ? or do i have to use TMT 5. ??
Hi All,
This motherboard has SPDIF. So just Buy the below plate and connect your Onkyo using a RCA cable or an optical cable. Don't buy the audio card. However just make sure that you have the motherboard manual so that you can connect the plate correctly to your motherboard. Also you have to set jumpers correctly on the PCB of the below plate. The below plate will come with a small instruction manual. Read it and set the jumpers correctly.
Which one to buy ??
I am using the same bracket for my MSI motherboard to connect to Yamaha RX-667 AVR. The bracket gives you SPDIF out on RCA as well as optical. I found better result using the RCA cable. With a player like monkeymedia and bypassing the windows mixer, I get very good results.
