Speaker Clamps
AtheK
Try mangalam electronics in SP Road. They have mounts made by them and also sell vantage point mounts. Thou I would suggest you to find space for stands and stand mount the bookshelf speakers.
Sure will give them a visit over the weekend, here is a pic of my current setup, you will understand there is no place for a stand currently. That can be in the plan for my next house, but for now do not have much of an option.
If i had the space i would have picked RTi A5 to begin with :P
From the back wall pics I see you have a decent size room, why dont you pull out those front L&R from that TV unit and keep them out side on stands.
Surrounds seem to be mounted too high.
Can you post a long view of your room ?
Experts here can advise you better on how to correct the setup.
Sure will do Tomorrow, what you do not see is the bed, the difference between bed and the closet is a little over 2 feet, so no place to make these boys stand up.
Surrounds are a bit high because if i pull them down a little more they will be right next to ear when we are sitting :)
