Speaker for onkyo tx sr 309 av receiver
shankaramurthy
Chennai
I recently purchased only tx sr 309 5.1 av receiver. I need to suggest speakers (including front, rear, centre - tower or shelf speakers ) or the above one. My budget is rs.30000. it is better if anyone suggest package one which includes all speakers . Kindly help me . Iam in chennai.
Taga Harmony TAV-606 SE Special Edition - 5.0 Set
Many FMs suggest this budget speaker package, you can buy it on ebay
Is soundbar like bose would be great to this av receiver
Soundbars are self sufficient. They don't need receiver. Since you already have the receiver, you should look at passive speakers. Taga harmony is a good option in your budget.
Sent from my ONEPLUS A3003 using Tapatalk
Consider Taga Harmony from hifimart.com
Taga Harmony Platinum S 90SL, - 12K per pair( for fronts & surrounds) - 24K - https://www.hifimart.com/taga-harmony-platinum-s-90-sl-bookshelf-surround-speaker-pair.html?search=Taga&description=true
Taga Harmony Platinum C 90 SL - 10K (Center channel) - https://www.hifimart.com/taga-harmony-platinum-c-90-sl-center-speaker.html?search=Taga&description=true
Totally 34K, slightly above (4K) your budget..You can later add sub..
