Speaker wall mount
saurabhpach
Gwalior, MP
Hi need to wall mount my klipsch rc62, can anybody suggest a suitable wall mount. It's about 12 inches deep, 24 inches long and 8 inch high, and it weighs 15 kgs or so. If the stand has the capability to incline, nothing like it. Please help :sad::sad::sad::sad::sad::sad::sad::sad:
One wild idea... you could try TV swivel brackets so that it could bear the load. But first check with a carpenter so that no parts are damaged while mounting the same.
Hi Magma,
Sorry for going off-topic here but I was wondering if you have any pics of the collars you manufacture fitted on to a granite slab. How does it get fixed on a piece of granite without protruding on the top side? It's a regular 0.75 inch granite.
the protrusion from the top side is inevitable
That calls for some brainstorming. I need something for my granite stands without anything showing up on top. I've got some ideas....let's see when I can execute them.
BTW, maybe you've already explained this before, but, why the ball bearings on the collar?
