Hi All,
I want few products, mentioned here under. Hence, need suggestions, inputs from Audio Gurus here.
1. Projector: Currently using Benq HT3050, bought new last year. Its a good stunning projector, but getting tempted towards Epson-5030UB or Sony- VPL45ES. Read reviews, but its almost tied. So which one?
2. BDP: Currently using Pioneer BDP 180, again bought last year. All good, but keen on Oppo. Question is 103D or 203? The confusion is, while 203 is 4K its future proof, but neither 4k content is available, nor my projector is 4k. As for 103D, should I expect significant PQ/SQ improvement over Pioneer 180? Let me know your views.
3. AVR: Currently using Marantz SR6010, bought new last year. Again no issues, and it indeed is smooth operator, very sweet. But new speakers am intending to purchase are considered to be power hungry, am advised to upgrade. So question is - a) Marantz SR 6010 + Ext Amps b) Anthem MRX 720 c) Separates pre-power? (PS: If current Marantz can work with new speakers, don't wish to change)
4. Speakers: Trickiest of all 'wanted'. Currently using Jamo 5.1. Works quite well, but want to go one-level up. Also, plan is to have 2 separate systems for Music (2.0) & Movies (5.1).
A) 5.1 (Movies): Dali Fazon, Paradign Cinema 200, Genelec 8010
B) 2.0 (Music): B&W 683/CM8/CM9 S2, Dali Opticon6/Rubicon6, KEF R500/700, MA Silver 6/8, Paradigm Prestige 75F
Alternatively, can also go with 5.0 identical BS/OnWall Speakers like -
A) Dali Opticon LCR
B) KEF LS50
Few imp things to be factored in:
1. Room Size: Diminutive. 10x11x9 feet
2. Reason for 2 systems: Small room has compelled me to go for Sats 5.1 (non-intrusive/small footprints). 2.0 can handle music (can also shift it later to living room)
Sound Signature:
Looking for speakers which are extremely pleasing to ears. Sound should be Open, Clean, Airy, Detailed, Wide Sound Stage, and WARM (cant handle slight harsh, sorry Klipsch). Hence, choice is NOT governed by how much BOOM/BANG a speaker can create in typical movie environment, but how SWEET it sounds in music.
Give the aforesaid, what would be your suggestions. Again, my first concern is RIGHT SPEAKERS. Matching system can be brought subsequently
Appreciate your response. Thanks.
DS
A) Dali Opticon LCR
B) KEF LS50
Sound Signature:
DS
