Speakers for vintaga Sansui 350A amplifier
Praveensubbarao
Bengaluru
Hello all,
I am looking for a good pair of budget speakers to pair with my Sansui 350a amplifier. I have shortlisted polk audio t15 and jbl stage 120. Please suggest which would be better or suggest any other speaker.
20WPC solid state - is it class A? I couldn't find much info - but it seems it is class A.
Checking the specs of the 2 speakers - atleast on Paper - it seems like the Polk will perhaps be a better match
89DB sensitivity vs 86db of JBL - it will "perhaps" be easier to get more volume out of polk.
45Hz lowest vs 60hz on JBL - Polk should go lower
5.25 inch vs 4.5 inch woofer on JBL - Polk should have better low end response.
***However all things on paper do not translate to reality! Based on a cursory glance at the specs - Polk seems a more logical choice.
If you can hear them both, decide based on that. If you are buying blind then maybe paper is your friend.
I have checked the manual and the schematics no where it's class is mentioned.
Checked the interwebs and could not find that info.
I listen to mostly classical, jazz and some rock music. I not looking for a speaker that is very loud but looking for nice clean sound.
I have connected a cd player and a cassette player.
