SPL Meter for HT calibration
skul82
Pune
Hello,
I was planning to buy SPL meter for calibrating my HT. Can anyone suggest any places in Pune? or online?
How do you plan to use the SPL meter ?
My understanding is that we need a signal generator for different frequencies with ability to feed each speaker individully , measure the response through a MiC or SPL meter and then apply an equalization correction. I feel it gets very complicated. Would prefer an automated correction to be applied based on the measurements from MIC inputs.
Does the below meet the above requirements?
IK Multimedia | ARC System 2
I am asking this as I have an SPL (radioshack)meter and could not utilize it beyond checking the SPL levels from the test tones generated by my Yamaha AVR. The YPAO was good enough.
I am asking this as I have an SPL (radioshack)meter and could not utilize it beyond checking the SPL levels from the test tones generated by my Marantz AVR. The YPAO was good enough.
Well, I was just going to use it against the test tones generated by AVR (Yamaha 299). I can use YPAO but i am not sure YPAO is gonna give accurate settings. I am not looking for a complext calibration, just a simple one.
I was basically only going to use it for Level correction. Now that I think of it, i will probably be wasting money on SPL meter if I use it only for level correction :o
How is your experience with YPAO? What tweaks you recommend after YPAO calibration?
As greenhorn suggested Android Apps are good enough for measuring SPLs.
YPAO does a good job of setting the Levels. The speaker distances are fairly accurate - except for the Sub where YPAO gives a higher distance. I remember reading somewhere that this is the way it should be for Low frequencies.You can do minor tweaks to the levels determined by YPAO based on your listening preferences.
