Stabilizer for 43" Plasma
Thank you. I have it from last year august. recently felt voltage fluctuation is frequent in the locality.
Thank to this forum, I come to know about the quality of Plasma. Feeling bad, I could not afford a full HD one. Hopefully, OLEDs will be cheaper by time of my next purchase.
If you want more equipment with stabilize like home theater, DTH, BluRay/Media player, SubWooper then go for V-Guard DIGI 200. Other wise Crystal Plus ok.
oh... i had planned to use bluray player+5.1 subwoofer with the crystal plus.....
will V-Guard DIGI 200 handle plasma tv+bluray+subwoofer all at once ?
I am using digi 200 which is 2007 model says 2kW capacity. It has 5A plug, and I made a loop in furniture where all sockets are going through digi 200.
V-Guard DIGI 200 has normal plug or that big 15amp plug ?
I purchase a 15 to normal converter for Rs.45. and using very well with normal plug. So no problem... you can go for DIGI 200. It's 6Amp model, handling very well with low and high voltages. (In my area voltage fluctuations are too much.). Now I am using it for my 5.1 Home theater and Active Subwoofer, Denon AVR, Himedia player, Tatasky HD Settop box, 40inch sony LED tv.
Since my 5.1 multimedia home theater dead due to recent voltage fluctuation, i just bought the crystal plus for connecting the TV and DTH. Quite satisfied.
Since you are using Plasma ,better to go for Digi 200 . I'm using the same for the 51" Plasma TV setup HT and Crystal plus for the LED TV setup HT along with Belkin surge protector.
For Digi 200 you a need 15amp plug.
Both are Good products.
