Stabilizer for av receiver
thomas2016
India
Do you think there is a necessity to place a stabiliser to the receiver? If so, which one would be better choice to make.
Thomas
It's took me 3 good reads to understand what you were asking for.
Lot of the members here use a brand called vertex.
A quick use of the search button would easily give you your answer.
Good luck.
If you have observed voltage fluctuation (or) if the voltage drops in the night, then good to add a stabiliser..
You can use the same one that is used for 1/1.5 Ton Air conditioners.. I have used it in the past and it worked without a glitch..
