Stabilizer Suggestion
jai123
NOIDA
I have bought a speaker system with rms value 500watts and 1000w peak. I wont be plugging anything else in the stabilizer. How much ampere should i look for in the voltage stabilizer (my budget is below 4k)
Stabilizer depends to amp not related to speaker ,
Could you share your amp details
Yes. Logitech z906. I know some people dont like it here but that was the best I could afford
Ok, no issue,
2KVA stabilizer is enough, please go with double or triple booster type.
If you have budget you can go with servo stabilizer,but little expensive
