K kkdeep Member Joined Dec 31, 2010 Messages 46 Points 8 Location Bangalore Feb 28, 2014 #1 Hi, i purchased a SONY ipod dock from US. The spec on the back says 33W. Will the following step down transformer be good enough. It is rated at 65W ebay link I have one table top transformer which I am currently using but the humming sound makes it almost unusable. --Thanks Kuldeep
blackscorpio Active Member Joined May 16, 2012 Messages 518 Points 43 Location Hyderabad Mar 4, 2014 #2 Yes, that is more than enough. But you could go for a 50W from a local store, lot of stores carry the Maxine brand. You will save couple of hundreds of rupees and Maxine is well regarded.
