Hello Experts,
I bought a AVR X2100 Denon from the US. To this amp I will be connecting 2 standing speakers, 1 center and 1 sub. The spec says power consumption is 500W. Based on reading from multiple threads I understand I need to get a 1KVA step down transformer. I was also hoping to connect my Samsung LED 55" TV (from the US) to the same step-down. I also have a voltage protection Panamax M8-AV-PRO which requires 120v line input (https://www.panamax.com/product/max-8-av-pro-8-ac-coax-and-tel-avm-line-filtration-M8-AV-PRO) and offers automatic voltage shut-off.
Guidance required on the below questions:
1) Can I use the same step down transformer to connect both my TV and Amp ? In that case will 1Kva be enough or do I need to go for 2KVA.
2) I have auto voltage shut-off plug point. Do I still need a stabiliser ?
3) Wall -> Step-down -> Voltage shut off extension -> Connect both TV and Amp. Will this work fine ?
Thanks all for the help.
