Hi Forum Members,
I have a 7.1 system with all speakers of Mirage that was imported from USA. Specifications are as below.
Mirage Nanosat 5.1
Power Rating 10 to 100W RMS/Channel
Frequency Response 110 Hz - 20 kHz
Impedance 8 Ohms nominal / 4 Ohms minimum
Crossover 2.7 kHz
Tweeter Tweeter: 3/4" (19 mm)
Woofer Woofer: 2 3/4" (70 mm)
Sensitivity 87 dB
Mirage Sub8
Power Output 75 Watts RMS
300 Watts dynamic peak
Woofer Down-firing 8" (203.2mm)
Voice Coil 1" (25.4mm)
Freq. Response (Rec/Repro) 33 - 120Hz
Phase Control 0, 180
Low Pass Crossover 40 - 150Hz @ 18dB/Octave
Driver 1.5" (378mm)
Weight 20.1 lb (9.1kg)
I want to split the setup into an occasionally used Home theater (5.1) for Projector and a Daily used (2.1) system for TV. I have an S8 subwoofer that came with the Mirage package for the 5.1 Now I am hunting for a VFM sub woofer for the 2.1 system. I request your honest feedback from amongst these or a new one in the price range of below 30k, lower the better. I am also open to swap the S8 to the 2.1 setup and have a more powerful home theater on the 5 1.
Shortlisted from among the options I have from the used ones are:
Dali Fazon Sub1 6.5" 100w 12k (2yrs)
Mission MS8 8" 100w 12k (5yrs)
Velodyne VA8100x 8" 100w 15k (12yrs)
Focal Cub2 8" 150w 15k (NA)
Elac Sub50 10" 100w 16.5k (4yrs)
Velodyne Deq8r 8" 180w 20k (7yrs)
Taga Harmony tsw212se 12" 240w 23k (3mos)
SVS PB2000 12" 500w 65k (NA)
DES 10" 200w 14k (NA)
Whole Sale seller, don't know model or age.
Onkyo 8" 10000
Jamo 10" 13000
MJ acoustic 10" 35000
Warfield 10" 180000
Any help/suggestions will be appreciated.
Thanks in advance.
Sandeep
Mirage Nanosat 5.1
Crossover 2.7 kHz
Sensitivity 87 dB
Mirage Sub8
Driver 1.5" (378mm)
Onkyo 8" 10000
Jamo 10" 13000
Warfield 10" 180000
Thanks in advance.
Sandeep
