Sub Woofer
MuraliJ
Hello,
I have a Yamaha rxv481 amp and Tannoy Eclipse 2 speakers and Tannoy Eclipse Centre. Would now like to go for a subwoofer. Can you kindly suggest a model in range of around 30K. Thanks in advance.
Hello,
Based on your budget and also what low frequency your existing speakers can deliver, pick a sub which can at least produce 10hz to 20hz lower then it makes sense....else going for a sub which can produce only 5 to 10hz lower will not make much difference....
https://htstore.in/index.php?route=product/category&path=109_61&sort=p.price&order=ASC
http://sayhifi.com/index.php?route=product/category&path=235_261#/sort=p.price/order=ASC/limit=25
http://www.profx.com/PoweredSubwoofers
https://www.ooberpad.com/collections/subwoofers
https://avstore.in/collections/subwoofers?sort_by=price-ascending
See who offers the best rate...audition and decide....all the best.....
Unable to decide between BIC F12 and BIC PL200 MKII. For a medium sized room (listining distance only little over 6 feet. width 15 feet) I think F12 would be better. Any expert suggestion. Also I am getting a good quote for Emotiva Basx S10. Need some expert advice.
If budget is not an issue, go with BIC PL200 MKII. It's a updated version over F12 and also front ported.
if not the BIC PL200 ii then look at Emotiva BassX S10....compare all specs and then take a call...audition where possible to decide....use the same content for auditioning
