its 2 yrs.And I thinnk not handlong lower frequencIes. As getting noise sme times may be due to frequency.And Currently using mx rca cable for sub. If I changed to rca cable like svs is it improves Performance.Had a Klipsch 150. It was fun. I think the Klipsch 120 will beat many subs under 50k. Why do you want to change the Klipsch 120 sub?
Any good subwoofer cable like svs can do better.It’s unlikely you will get a sub that handles lower frequencies at a respectable SPL than the Klipsch 120 under 50k. You may have to significantly increase your budget for what you are looking for. If I were you, I would stick with the 120 and fix any niggles it might have.
Keep Ascendo sv12 in the list.After klipdch 120 next is svspb 1000
Heard great about it. And xtz 10.17 Also.Keep Ascendo sv12 in the list.
6 mm is a good carpet. I use 1 mm or so and it works just fine. I have additional acoustic panels in place.Thiknking any placemrnt issue for ascendo as only svaioabke place is between 2 front towerS.
Nearly 10feet from lidtrning position .Even ghoufh room size is 25feet length and 15 feet wiidth.
And what is the thickness we need for carpet. 6MM is good.?
mine is in living room. No panels. But sofas there.6 mm is a good carpet. I use 1 mm or so and it works just fine. I have additional acoustic panels in place.
Previously i had owned Sonodyne Roar 1210. It was good . But comparing to your klipsch 120 you will not feel much upgrade to Sonodyne Sub 1010. It has more tuning options comparing to Roarr series , but otherwise specs were same. If its your first sub then worth considering Sonodyne sub 1010.What about the Sonodyne Sub 1010? I havent heard much of it in these forums, but I ve heard that the 1010 and 1012 are pretty good value for money at ~50K and 75K
6 mm should cut down the floor reflections quite a bit especially in upper region of frequencies.mine is in living room. No panels. But sofas there.
Hows kliosxh Rp1000 and spl 120.6 mm should cut down the floor reflections quite a bit especially in upper region of frequencies.
Svs mostly focus on deep bass below 25 hz and its moderate there. So, I would pick up a sub that does 25-30 hz but does a god job of frequencies above it. To attain good spl of 25 hz and below you would need a large driver. 12 inch just don’t cut in. Or, you need a huge ported box which is no practical for home usage.Hows kliosxh Rp1000 and spl 120.
Got good quote for svs 1000 and Pro
ascendo sv 12?Svs mostly focus on deep bass below 25 hz and its moderate there. So, I would pick up a sub that does 25-30 hz but does a god job of frequencies above it. To attain good spl of 25 hz and below you would need a large driver. 12 inch just don’t cut in. Or, you need a huge ported box which is no practical for home usage.
It should be good. I haven't had a demo yet, but it is good based on other FMs' experiences.ascendo sv 12?
how is klipdcj spl150It should be good. I haven't had a demo yet, but it is good based on other FMs' experiences.
