Suggest 40/42 Inch TV - NO Internet & 3D
narsing_india
Hyderabad
Kindly suggest an 40/42 Inch TV - My requirements are
1)40/42 Inch - LED TV only (No Plasma or LCD!!)
2)Full HD preferred
3)Strictly NO Internet, NO 3D
4)-95% use will be watch for Standard TV channels
-3% use would be to watch movies from DVD, External Hard Disk,
Pen Drives, Laptop, Desktop
-2% would be to play games from Xbox,Ps2 or Wii.
5)Connectivity to external source should be good.
Example : External Hard disk, Pen Drives, Laptops, Desktops, DVD player,
Xbox or PS2
6)High Quality and Good life with 0 Maintenance
7)Should serve atleast next 10+ Years (My current TV served me 11
Years and still going on..)
8)Price : Value for Money
While suggesting, kindly quote the tentative price of model too.
Advance Thanks for all comments
My budget is open as of now(thinking around 40-60k, can extend if required).
Kindly DON'T point to model based on budget and consider only my requirement for suggesting.
Sony 40ex650 is good buy for a budget of around 65k.
Samsung 40eh5000 for a budget of 50k.
2)Full HD preferred
Xbox or PS2
The models which have good PQ automatically have Internet and sometimes 3D also..
Sony 40EX650 is good buy for LED for good PQ for normal TV channels..
I recently bought a Sony 40EX430 ... operating fine. This is a direct-LED type design which is a bit different from the earlier introduced edge-LED.
Check its specs and see whether it complies with your requirements ... within your budget too.
For your needs, I would suggest the Sony 40EX430 or Samsung 5 Series. LG has introduced so many models that it is difficult to find the correct one. I think that they (LG) should take a relook at the strategy. For what is the need for LM6690 and LN6700 both?
