Suggest a Stabilizer for my 47 inches LG LED TV
kskmbbs
kurnool
Hi to all
Suggest me a Stabilizer for my 47 inches LG LED TV...
I am Dilemma ...
whether I go for V-Guard Crystal Plus or V-Guard DIGI 200
this is my Setup
1) LG 47LM8600 3D Cinema HDTV
2) Videocon d2h HD or Tata Sky HD
3) occasionally PS3...
Please Help me on this...
those who r using TV's of 47 Inches and Above Plz Suggest me a Stabilzer
Thanks in Advance..... :tup:tup
V-Guard Crystal Plus Feature : V-Guard Crystal Plus Voltage Stabilizer - V-Guard: Flipkart.com
V-Guard DIGI 200 Features : http://www.flipkart.com/v-guard-digi-200-voltage-stabilizer/p/itmd7kkzhstzqmas?pid=VSTD7KKGKD4GXGMP&ref=e8296009-dc8c-40de-9822-216a4ae8340f
PS : DIGI 200 has 16 Amp Power Socket
thanks in Advance..
Yes the V-Guard Crystal Plus will be more than enough for the LG42" TV.
This has High Voltage Cut-off: 290 V Input (240 V Output), Capacity 3 Amps, 120 - 290 V Input Voltage Range
Thanks! But as per the below specification: It supports only upto 1.3Amps not 3 Amps it seems.
Other Power Features High Voltage Cut-off: 290 V Input (240 V Output), Capacity 1.3 Amps, 90 - 290 V Input Voltage Range
@ Record Player...
is Crystal Plus Enough or not For my Setup....
Plz Help me Regard this
this is my Setup
3amp stabilizer can handle even 500W easily. Your TV and stb will draw a maximum of 100W. Even the 1.3A crystal mini can be used.
