Hi Folks,
Can anyone suggest some good ON-WALL speakers for my 5.1 home theatre setup for mounting around my LED screen in my new living room. I don't have the option for floor standers so have to suffice with wall mounted options. There is also this problem of aesthetics as it's my living room.
Was looking at the polk OWM5, Dali Fazon/Ikon series, Paradigm Millenia, Klipsch etc but quite confused and some are way out of my budget.
Budget - 70K to 1 Lakh for 5 speaker setup and 30K to 40K for the Sub-woofer.
Primary Use : Music & Movies.
Receiver : Will be using with my Yamaha RX-V475.
Living room size : 13 ft x 10 ft.
Willing to mix n match for surrounds. Surrounds will be mounted near ceiling. Will prefer 3-way LCR options for the Left, Right and Center speakers as it will be even used for stereo music.
