Suggest the best 32" Full HD LED for me within Rs 36000
astroboy89
Kolkata
I have the following models in Mind:
Samsung 32EH5000
Sony 32EX650 or EX520
LG 32LS4600
Philips 32PFL4556 V7
I want excellent picture and sound quality with vivid color.No motion lag.Sufficient connectors.Plays most video and audio formats thru USB and recognizes them easily.Will watch it in bedroom with a viewing distance of about 8-10 ft.I will sometimes hook MY PC for gaming via HDMI(I have ATI HD4770).
Please suggest the best possible model for me and it should be full HD.
I am planning to but Videocon d2h HD.Will the HD and SD channels look good in it?
one suggestion please buy semi hd..at 32 inch u wont find the difference that too at a dist of 8 ft......use the extra saved money for upgrading other systems..u can experiment it side by side in a showwroom.........
no system can gurantee to play alll usb file type.best is to buy a o play mini from asus..
also try ur usb in sony/samsung/lg/pana/toshiba and check which will play easier and most of them..
tv self speakers are not meant for great sound...
in my opinion buy an asus player(although u have ur pc..so why worry)..cheap speaker set intex/creative and a semi hd led within 36k total......
I will be in kolkata around sep 22..23..24...can acompany you for demo...
yah at 32 inch digital sd channels look decent...
pana and toshiba has 32 inch at a very attractive rates..check it..
and within ur budget if you want a big screen further..option is semi hd 42 inch plasma by pana...exactly at 36k...can give it a thought.......only plasma can offer u zero motion lag at this budget......
Sony will offer best picture quality..as you are connecting your pc to tv you can play various format via pc also...else you can go with the samsung model for playback of various format.
I would also suggest the Panasonic 32E5d, comes in 2 panel colors, white and black and more over ips led panel seems solid. and the blacks i felt was much better or similar to the sony, samsung.
Panasonic and Lg use IPS panel which offer wide viewing angle but bad black level and contrast ratio. Sony and samsung use SPVA panel which offer much higher contrast ratio and very good black level..hence you will get much better pic quality...and where do u get impression that IPS got better build quality than SPVA..
To OP: If you are not going to upgrade this TV in next 3 years, then buy Sony EX650.
Else, you should buy a 32" LCD that is HD-Ready. For a small panel, HD-Ready (720p) is not going to be way inferior than Full-HD (1080p). Further, if you are going to watch DTH only (mostly SD) then Full-HD is not going to make any difference. Going still further, at a distance of 8~10 ft., the difference between HDR and FHD is almost nil.
Don't take my word for it ... go to a showroom and see for yourself.
An HD-Ready 36" LCD will cost no more than 25k (Sony/Samsung/LG/Panasonic) to 20k (Videocon).
