Subbiya
I guess my searching for speakers finally ends here...
Last week, I did audition with Dali Zensor 5 @Grand Cinema, sound was good, I can able to hear different instrument sound, & female voice clearly. But I don't feel that there is much bass as expected. The problem is, I need to keep the sound atleast 50% volume, below it I was not able to hear clear sound(different instruments). Is this is the problem with my onkyo-828 receiver.
I guess, I should go with Dali Zensor 7 which is 2db > Dali 5 in sensitivity. Also low frequency is some what less than Dali 5.
Another problem is my onkyo receiver 828, handles 180/ch @6ohms, the speakers are rated to handle B/W 40 - 150W, I agree no one will be listening to the speakers @100% of volume. But what happens, If I play the speakers above 85% which is 153W from 180W which is not recommended for these speakers.
Does the speakers will be able to handle the power output from my receiver. ?
I found the below article, which says the receiver power should be 10% greater than the power of speakers.
How to choose the right speakers for your amplifier or AV receiver
One thing, I want to mention here. I have created a lot many of thread for my speaker search. every where I mentioned about my receiver power wattage. And I actually not able to understand, how to match the power of speakers with my onkyo receiver.
Below is the watts specification given in manual that comes with the receiver.
130Watts/Channel @ 8ohms (FTC)
180Watts/Channel @ 6ohms (IEC)
215Watts/Channel @ 6ohms (JEITA)
Please explain me, from above which 6ohms watts will be used for driving these speakers.
User manual for Onkyo-TX-NR828 from the onkyo website shows different wattage. Pls refer the attachment.
for using speakers with 6ohms, do I need to change the speaker impendance set to 6 ohms in my receiver, but this was recommended in onkyo manual.
I really need to end my searching for floor standers, it was almost 2 years, I was searching for FS which sound good to me @ low cost.
Please help..:sos:
Thanks,
Subbiya
Please help..:sos:
Thanks,
Subbiya
