Yes, they are Klipsch speakers.are the speakers sealed cabinet ?
I think these have a rear bass-reflex portare the speakers sealed cabinet ?
Absolutely right! I really don't have space where I can place the SUB. It is triggered only when I watch movies which is very less.@SachinChavan i think sub plays a role mostly in movies in this setup. Even though position though looks more out of convenience
Is this to tackle SBIR?keep the ratio 8:5 - the distance from back wall and side wall should be in 8:5 or 5:8 for optimal sound
I have observed that if we have a furniture in the middle, especially furniture which is covered from all sides and not airy like a rack, then sound quality suffers. Though this one is not completely covered from all sides, however it has many surface areas which block the sound wave movement.
Any literature to help understand the logic behind this ratio? Also how do you measure? From driver to front wall or speaker rear to front wall. From closest edge to side wall or speaker center to side wall?
Interestingly, I measured the depth (32 cm) and breadth (20 cm) of my speakers. It is exactly in that 8:5 ratio!
