Hello everyone,
I have a Yamaha HTR 2067 AVR and TAGA Harmony 606 SE speakers.
This is the speaker spec:
Floorstanding Speakers
Crossover points 650Hz, 4.5kHz
High-Frequency Driver: 25mm (1"), TWG faceplate
Midrange Driver: 133mm (5.25")
Bass Driver: 2 x 165mm (6.5") (16.5 cm)
Recommended Amplifier Power: 20-150W
Frequency Response: 36Hz-25KHz
Impedance: 6 ohm
Sensitivity: 91 dB
Center Speaker
Crossover points 4.5kHz
High-Frequency Driver: 25mm (1"), , TWG faceplate
Bass / Midrange Driver: 2 x 102mm (4")
Recommended Amplifier Power: 20-100W
Frequency Response: 52Hz-25KHz
Impedance: 6 ohm
Sensitivity: 88 dB
Surround Speakers
Bass / Midrange Driver: 102mm (4")
Impedance: 6 ohm
Sensitivity: 88 dB
There is a Sony Sub Woofer at 140 watts at 3 ohms, 80 Hz, 10% THD
The input for AVR is ASUS O!Play Mini.
Video part is Samsung Plasma TV.
Can someone please suggest/guide on setting this up for optimal movie viewing?
Thanks in advance.
Regards.
Impedance: 6 ohm
Sensitivity: 91 dB
Center Speaker
Impedance: 6 ohm
Sensitivity: 88 dB
Surround Speakers
Impedance: 6 ohm
Sensitivity: 88 dB
Thanks in advance.
Regards.
