Suggestions needed for 55 inch tv
srikanths
india
Enquired 2 tvs in Hyderabad bajaj electronics. Sony 55W800D hd 1080 tv -after discount 1.08 lakh (before discount 1.19 lakh). Sony 55X800D 4k tv -after discount 1.49 lakh (before discount 1.7 lakh). Let me know your suggestions. Any other TVs to consider.
Have a look at K6300 Samsung Curved as well. Similar pricing. Not a lot of reviews for W800D. Let the experts drop in their suggestions.
Picked up a Philips recently. But whichever one you buy ensure you have enough distance between you and the tv. Thx etc recommends only 9-10 feet distance but practically it's too less.
Thanks for the suggestion. It should not be as problem but Will keep the distance in mind.
Thanks. Will have a look into it
Sent from my LYF_LS-4006 using Tapatalk
Curved TVs do not give tangible benefit over flat except aesthetics. They exaggerate reflections and limits viewing angle. Some makers claim enhanced sense of depth but you need to be at sweet spot.
I would advise to check the cost difference and spend only if you are convinced.
