Very good for movies, but not liking it much for music has it lacks mid bass punch.
being big in size placement is an issue, but its good for movies. It goes deep at times and rumble is also good. The mid bass is missing for music when i compare with the deftech which i have alsoI think you may have an issue with the location of your sub. Have you measured your sub in the room?
PB 3000 is available in India?
This is a thread for SVS SUBWOOFER OWNERS only. Post you buying experience, reason to buy the svs, prices,deals, reviews etc here.
Other members who don’t own the svs please refrain from posting and asking for what should I buy posts. There are plenty of other threads for that on the forum to guide you.
Please guide how to set it up to get proper bass and punch. With regards. VinayakaAhh finally there is an SVS thread. After going through around 5 subs, I finally found an SVS PB1000. Its a Beast. Placed it in my the most preffered spot and it can help one get over arthritis, physiotherapy, etc. The punch is strong, precise and sufficient. Many FMs have visited home and experienced it. None, said that they wanted more, the bass is just right at any volume. Setting up an SVS sub is the Key. There are minor differences to the usual methods, Googling for them will help a lot.
I use it for Movies only and its a keeper for life.
MaSh
HiAhh finally there is an SVS thread. After going through around 5 subs, I finally found an SVS PB1000. Its a Beast. Placed it in my the most preffered spot and it can help one get over arthritis, physiotherapy, etc. The punch is strong, precise and sufficient. Many FMs have visited home and experienced it. None, said that they wanted more, the bass is just right at any volume. Setting up an SVS sub is the Key. There are minor differences to the usual methods, Googling for them will help a lot.
MaSh
Being a big sub, i have limitation of placement in my living room. do not have a dedicated HT room. I can easily make out the bass missing while playing few track which were present when playing through the deftech.Was the DefTech in the same location as the SVS? If not, please move the DefTech to the same location and see if it gives you the mid bass while the other doesn't. I'd suggest it wont, but it is an experiment you should try for yourself.
Mid bass is mid bass (however you define it), irrespective of whether it is movies or music. My guess is, for you, the tactile feel from ULF in movies is compensating for the lack of mid bass.
Please measure the subs in your room. A whole host of issues are due to the room, the placement of the sub(s) and the listening position.
Ok will tryout. currently using the lfe input on the sub. Setting on avr is 80hz.What is the LFE setting on AVR for sub? Have you tried toggling up or down frequencies? It makes a difference...
The sub is kept in the front and the phase is turned to 180 degrees since it sounded better there.
