Suddenly my DS212J has become inaccessible. I cannot connect either through IP address OR access the share. In fact it is not picking up any IP address. My modem shows that there is no IP assigned to it through DHCP.
The LAN light in the front of synology shows status as active but if i check the back where we insert the LAN cable the lights next to LAN cable don't light up(which I read on forums could be as designed as some of the models dont lit up the back LAN light).
I have tried resetting it but it didn't help. Now I have reset it twice and as per the lights status I should set it up now. But if i check my modem admin page , the NAS is not getting an IP at all. I have also tried to change cables, switch network ports. I also tried using a supported TP link wifi dongle but its not showing up on network no matter what. Any thing that I can try ?
