Hi,Hi guys, I find a deal for 607 for 42k .. the price is really pleasing me compared to POLK Signature setup which is costing me 2 lakh almost
is the quality of TAGA any match to POLK ?
Please share your honest opinion
Not sure about Taga but Polk Signature has a bright (metallic) kind of sound signature and the Polk RTI series has a warmer sound signature. Hope it helps.Hi guys, I find a deal for 607 for 42k .. the price is really pleasing me compared to POLK Signature setup which is costing me 2 lakh almost
As rightly mentioned, Polk signature series has bright, ear piercing sound. In acoustically treated room you can still get away with them, but in case you are planning to put them in your living room, they will cause ear fatigue very soon. Haven't auditioned Taga, so cannot help with the comparisonHi guys, I find a deal for 607 for 42k .. the price is really pleasing me compared to POLK Signature setup which is costing me 2 lakh almost
Which AV do you suggest for the POLK Signature series bro ? I been confused between Yamaha and DenonHi,
Around 2 years back, i had demo Polk Signature series setup [S20 as front L+R, S30 as center, S10 as rears, OWM as heights with Polk HTS12 sub] combined with Yamaha 7.2 AVR in a showroom. I was totally blown off and impressed with the aggressiveness of the sound. I liked the dynamic, bright and tight sound of the entire setup.
After coming back to home, i immediately played the same movie clips in the same atmos codec in my taga 606 v3 setup. I was little disappointed. That punch was missing [can't define in exact words]. I know that my room is not soundproof treated, but even then there was difference of 15/20 in both the setup.
This is the closest i can differentiate between the setup. Polk signature series is much better compared to Taga. If you are inclined towards movies, then instead of Polk towers; you can go for polk bookshelf speakers and subwoofer.
HI , Which AV can give best output for POLK ?As suggested by @Michelangalo & @Pratyush J , Polk signature series are bright, detailed and ear piercing. Sorry, i was not getting the exact words to define. But, Taga's are warm and laid back. So, it all depends upon your taste.
HI , Which AV can give best output for POLK ?Not sure about Taga but Polk Signature has a bright (metallic) kind of sound signature and the Polk RTI series has a warmer sound signature. Hope it helps.
HI , Which AV can give best output for POLK ?As rightly mentioned, Polk signature series has bright, ear piercing sound. In acoustically treated room you can still get away with them, but in case you are planning to put them in your living room, they will cause ear fatigue very soon. Haven't auditioned Taga, so cannot help with the comparison
For polk Marantz and denon are recommendedHI , Which AV can give best output for POLK ?
Some people suggesting yamaha .. I been very confused hahaFor polk Marantz and denon are recommended
Denon and Marantz have Audessy Audio calibration and Yamaha has their proprietary calibration tool. Yamaha offers more ports for less money. Resel value for denon will be higher than Yamaha. When I was looking for AVR I had Pioneer, Yamaha and Denon in mind and went for Denon. Thumb rule is decide speakers first and based on the speaker requirements choose AVR.Some people suggesting yamaha .. I been very confused haha
How easy is to configure denon bro ? I heard Yamaha have mobile app where we can control everything from phone .. does denon have such an app ?
Both are good. Most of the members have Denon + Polk combo. You can go ahead with Denon AVR, to play safe.Which AV do you suggest for the POLK Signature series bro ? I been confused between Yamaha and Denon
