Taga Harmony Best Combi?
chlorophyll
INDIA
keeping Yamaha HTR 3067 avr in common for al
1.TAGA Harmony TAV-606 v3
2.TAGA Harmony TAV-606 SE
3.TAGA Harmony inMove 5.1 system
movies 70% & music 30% - guys please tel me which one is the best combi.
If Yamaha htr 3067 is the wrong choice for them pls tel which avr is good for TAGA.
Please dont mind am asking too many doubts.:sad:
thanks in advance.
thanks in advance.
Taga inmove 5.1 system.. But you can also consider 606 SE if you could scout one around..
I would suggest buy it from ebay.in "s-Grid" is the seller who sells same products in ebay and amazon as well.
Buying from ebay you will get offers as well so it will be much cheaper by 3 to5k.
Anil
If movies are 70%,then Taga package will go well with yamaha.TAV-606se has more sensitivity and Yamaha can drive them well.
I will suggest you instead of entry level 5.1 set go for quality 2.0 set with your Yamaha. I have audition Taga Azure floor standing speakers. Tonally balance, Natural and warm sounding speaker. Later on you can add rest of the speakers as budget. Within 2 to 3 years , you will have quality home theater system. Check pre owned section also, you may get good AVR at reasonable price. Entry level AVR may not bring best out of a Floor standing speaker as they need more power to perform well.
Sent from my Le X507 using Tapatalk
