theironhorse
connection was taken in nov 2010..
till a few days back it was working flawlessly and once fine day the box/?? starts acting weird..
it starting loosing settings.. every time i turn on the box it will ask for initial setup.. where i kept going next ..next and then the normal channel 100..
it went for a few days and now the box shows a green light but no signal.. if i leave it like the same way for sometimes 20 minutes - 60 minutes it will again pop-up the initial setup and work like nothing ever happened and suddenly after 10 minutes the screen goes blank and no signal...
the box will still show green light.. after 20-30 minutes it will come back again with the same channel playing....
2 seperate issues.
sometimes it just does not start at all.. but shows green light when power button pressed on remote like it starts up normally and will come up randomly with the initial setup screen again.
second while watching any channel the screen goes blank .. no signal again and comes back after random time to the same channel.. ( not restarting but just the display going off)..
i believe it is out of warranty.. for over an year..not sure what needs to be done.. also no signs of heat.. cleaned the box with compressed air as well.. no go...
2 seperate issues.
