Website: https://www.tidal-audio.com/contriva/
TIDAL Contriva (G3 – Third Generation), Dynamic 3-way Loudspeaker
- multi chamber cabinet made of TIDAL's proprietary cabinet material TIRALIT and TIRADUR cabinet material
- 1 x exclusive 30mm Gen3 diamond tweeter with neodymium under-hang motor
- 1 x exclusive 173mm Gen4 black ceramic midrange with neodymium under-hang motor
- 2 x exclusive 220mm carbon-fiber aluminum woofers with neodymium long excursion under-hang motor
- TIDAL uno-pulse crossover with lowest tolerance components, micro phonically and hermetically isolated in separated chamber
- Gen-3 TIDAL isolators with 8 x trigger-bars, made of stainless-steel high gloss polished
- cabinet finish: original TIDAL piano lacquer in midnight black and hand selected veneers in original TIDAL transparent piano lacquer
- nominal power handling: 150 / 300 VA, nominal impedance: 4 Ohm, recommended power amplifier: > 30 watt.
- 2 x 114 Kg weight (without packaging)
- speaker dimensions: 130 cm x 27,5 cm x 48 cm
