Thin yellow line on Panasonic plasma
thirurajesh
Chennai
I got a thin yellowish line on my panasonic plasma st30 which is less than 2 months old. It was working fine and it came when I switched on the TV test night. When I googled I saw posts mentioning about a panel issue. I just called the customer care and they will be sending an engineer tomm. Keeping my fingers crossed :sad:.
:sad:
can u share some pics...? Is this happening for all sources like DTH, USB vedio, etc?
Good luck with getting this resolved...hope it is just a minor glitch
Check if this line persists when using multiple sources- DVD , STB etc. In case so then there is a problem with the panel. Call up Panasonic , they will replace your TV with a new one.
Faced a similar issue after 1 year of purchase on my Pana VT20 . Thankfully TV was under 3 year warranty. Panasonic guys gave me a new set.
Yes its with all sources.Since its yellow, it appears black and very evident on Tatasky blue background. I called up Panasonic and the engineer is expected today evening. Hope its gets resolved.
I have 2 updates
Update 1: Panasonic engineer came and took some pictures and told they will provide a replacement after approval. Again another person came and took few more pics and opened the Tv and noted down the panel number.
Update 2: The thin yellow line became a thick black bar( around 1.5" width) since today morning the TV is not watchable now :mad::annoyed:
Hope it gets replaced soon!!!
I have 2 updates
They had opened back panel cover for its serial number in my case too.
It should get replaced although it will take some time (took about 1 month for me). Have they taken pics of thick bar? If not escalate this and mention TV is not watchable and you need immediate replacement.
