I was wondering if I should make a switch to Qobuz after being with Tidal for over 2 years. With some feedback from fellow FMs, I got to testing...
**Please note my observations are subjective and the choice is dependant on the system and personal preference. If you are in similar shoes then try both services for yourself and decide what works best for you.
The comparison was done via Audirvana Plus on an upgraded MacMini (details in sigature). I added the same test tracks to favorites on both Tidal and Qobuz and these show up at one place on the A+ iOS app. I select a track on Qobuz and use the “Play Next” option to add the Tidal track to the queue. This way I could easily switch between tracks to do an AB test.
Test Playlist: About 100 tracks
Blues, Jazz, Vocal, Acoustic, Folk, New Age, Classic, Dance, Lounge, Country, Electronic, R&B, Instrumental, Rock, Metal, Orchestra, Pop, and Regional.
Catalog: Tidal
Transferred over 3000 tracks from Tidal to Qobuz with SongShift on iOS. Couldn’t find about 8% of the tracks on Qobuz. This is a bummer!
Album Art & Metadata: Tidal
Picked random tracks and checked for cover art & metadata against official artist websites/google. Tidal seemed to be more accurate. Qobuz rarely had the artist and album names mixed up, and dated or inaccurate cover art. Not a major issue.
Bitrate: Qobuz
Roughly about 10% of the time I came across tracks that were available at a higher bitrate on Qobuz. But I couldn’t hear any difference between a higher bitrate track on Qobuz vs the lower bitrate one on Tidal, so didn’t consider it as a differentiator.
Bass: Tidal
Just a tad bit tighter on Tidal. The difference is small but noticeable.
Vocals: Tidal
On Qobuz vocals are more forward (some folks may prefer it this way). I also felt they were a bit hazy around the edges. For me, vocals on Tidal made more sense. They were better defined. Weight, body, and openness, etc were the same though.
Control, Focus, and Separation: Tidal
Better control over bass resulted in better focus and separation with Tidal.
Cleanness: Tidal
It felt cleaner. Maybe because of better control over the bass.
I did not notice any difference in highs, resolution, dynamics, soundstage, tonality, imaging, detail, presence, presentation, and musicality.
For me, Tidal was a clear winner because it sounded cleaner with tighter bass, focus, and separation. I'm paying ₹100/month for Tidal whereas Qobuz would around ₹350 if shared. Qobuz had to sound better for me to make the switch, but that wasn't the case. So decided to stick with it. However, for others, the choice could be different based on the system and personal preference.
My system details are in the signature if anyone is interested.
In early 2019 I tried Tidal native app (and Roon) before getting Audirvana Plus. A+ sounds much better to me. I haven’t compared A+ with Qobuz native app, but I doubt Qobuz would win.
Some people mentioned they prefer Qobuz in another thread. So I’m assuming folks who prefer Qobuz have compared the native apps only?
If anyone tested via A+ or Roon…please share your thoughts.
Catalog: Tidal
Bitrate: Qobuz
Bass: Tidal
Vocals: Tidal
Cleanness: Tidal
