Tilt Wall Mount for 46" LCD (Not LED)
mgdelhi
Gurgaon
Is it possible to use a Tilt wall mount for my Samsung 46B530 LCD like the one that comes with Samsung LED TVs.
If yes, are they normal tilt wall mounts that comes with 46 LED TV which I can buy from Gaffar Market or do I need any special tilt wall mount to bear extra weight that LCD TVs carry as compared to LED TVs.
I am getting my room re-done today/tomorrow so an early reply will be appreciated.
I am not prepared to wait for 15-20 days to get Amazon wall mount through shopyourworld. It's shipping weight is also 11.34kg.
So, I will consider all available option till this evening and then take a decision. :)
Samsung engineer called. He said that he has an option in which I will need t pull the TV from the bottom, hold it like that and then connect/disconnect the cable, then leave the TV softly.
This option is for Rs.2,800/- and is available now.
He said the wall mount of 46" LED TV can also be installed without any problem and it has more tilt options. But the nuts needed for it are not in stock and he will get it next week. The Samsung MRP of this mount is Rs.9,990/- but he will do it for same Rs.2,800/-.
Is it any good ?
