whatzisnem
Hi all !
My system currently is a Acoustic Portrait Swara integrated amp and Cadence Arita bookshelves. My source is Flac streamed from my android phone via Hi-Fi cast to Chromecast Audio.
Will introducing a budget DAC( specifically a Topping D30 Or a SMSL Sanskrit 6th -there has to be a digital in to enable use of the digital out of the CCA , as it supposedly sound better. I'm curently using the analog out of the CCA to the Swara. ) make any appreciable difference to the sound quality ?? . There is supposed to be a decent DAC in the CCA, but considering the size ,how good can it possible be ?.
It has to be a budget dac or none at all..I'm not a golden eared audiophile and also ,cannot afford the expensive stuff !
thanks in advance for your opinions..
