Triad Gold Series In Room LCR vs MK S300 LCR?
Meyer34
Nagpur
Hello everyone, I am new here. I'm contemplating a 9.2.4 with either the choice of Triad Gold or MK S300 LCRs. Basically the whole setup with subs and surround is with either of those brands. No way I can get an unbiased review with each vendor claiming theirs is the better one. Kindly help. Thanks to the community
Hello,
Both are well reviewed and well known . In many of these there is no "Better' as it is an individuals perspective based on how they like to hear.
If you have heard both and like one , go for that. If you like both go for the cheaper of toss a coin as you will not go wrong with either .
Triad gold is better than mk s300 lcr. mainly due to the problematic design of mks s300. which you can find in the measurements data. also you can consider many other brands like jbl synthesis or procella in that price range. buy from someone who knows total info(dispersion, dynamics, distortion levels etc ) about the products ,so that it can be integrated well to your room.
