cybermantas
Hi everyone
I am looking to buy a 55 inch TV in the range of 50-70k. I think most options closer to 50k would suffice, but if there are very strong "bang-for-the-buck" recommendations at a slight premium, then I am happy to stretch the budget to 70k also.
Here are my thoughts:
1. OLED seems more expensive (please tell if otherwise). QLED / QNED options (with mini LED and all related jargons) seems like a good compromise for the budget and the features
2. Looking for a budget range of ~50k but "bang for buck" is most important. Happy to go higher if the product performance is much better for the price premium
3. Use case is TV for bedroom, so lighting is not an issue (dark curtains in the bedroom). Only for OTT watching (Netflix, Prime, Youtube, etc.). Angles are not a challenge. Gaming is an additional use case but only a good to have. Not needed otherwise. No additional sound setup, so the TV speakers will be main speakers. Can upgrade this in future if needed, so not concerned on this for now.
4. Looking at Hisense based on this article (https://www.rtings.com/tv/reviews/hisense). This suggests that Hisense has good TVs in mid-range and offers better performance vs Samsung, Sony, LG in non-OLED options.
5. Narrowed down to Hisense U6N Pro (50k) / Q7N (50k) / U7N (Price currentlty unknown). Any comparison and feedback on which to chose between these 3 and which channel (Amazon / Offline) etc. ? And any other suggestion from competing TVs from Samsung / LG / Song or others that need to be considered ?
Thanks for the help!
