TV Wall Mount Recommendations please!
SatMumbai
BOM, BLR, DE
Hi, We are currently getting interiors done. The plan is to have a 75" TV now but may be change it to an 85" in some years. Can you recommend me a wall mount for TV which can work for both and does not break bank? Would prefer some amount of articulation as I plan to install the mount on the wall and there will be wall panel on the TV so that I can get the TV as flush as possible to the wooden wall panel (but also pull forward if needed for connecting any cables etc)
Cheap TV Mounts are made with materials of questionable integrity. The might bend or give under the weight. If you are looking for a fixed mount you can go with the one that you find in your budget but verify the weight capacity before buying.
If you want a fully articulated mount, you might have to spend a good amount as it will be carrying an expensive TV.
USX MOUNT, ECHOGEAR, Sanus, etc.
I don't have personal experiences with any of these, but I have listed them down for future references. Please do your own research before making purchases.
