TWS suggestions under 20k
altair21
India
I know another repeat thread but hear me out folks, I have explored other recommendations but none exactly fit my criteria:
I am pretty much an amateur when it comes to Speakers/DACs or anything related to it, I prefer using earphones which do not exaggerate anything, with a preference for clearer vocals, with a let's say a strong distaste for bass, I have been lately listening to instrumentals a lot, so anything that'll be good for them is a major plus for me,
from my initial search and looking at reviews, IEMs seems to be the best bet for me, but getting a Bluetooth DAC for them is a little out of my range for now, so TWS it is (main priority is no physical connection to my phone, I have damaged the ports of nearly all the phones I have used with earphones/headphones) and from my shortlist only Sennheiser Momentum 4 seems to fit the bill, they are a little out of budget but should hopefully be cheaper by next year or at least around 15-16k mark.
Are there any other recommendations for me?
For 20K you can get a BT DAC and IEM that will be leagues and eons better than any TWS. Get the Sennheiser IE 200 and the Fiio BTR15, call it a day and thank me later.
If you want the convenience of calls and things then the Samsung Galaxy Buds 3 Pro are the best I have heard and are quite good at other things as well. But as I have stated, the Buds 3 are no match sonically for the Sennheiser and Fiio.
can you give some suggestions? for the DAC, I looked into BT DACS but decent ones alone were costing almost 20k,
I dont need them for calls, I have a daily driver for them, I just want pure sound
