Universal remote Info needed
uziel
New Delhi
I am looking for a basic remote with two main features(a) Learning and (b) glowing or backlit key, just 2 devices to control, no lcd no highfi,budget under 1000, any recommendations.
A budget universal remote may not have a future learning capability and hence you should consider Logitech's HARMONY model which is widely used and works well with almost all electronics...
harmony 650...i felt like biting a grenade ...expensive and all that shit..
but totally worth the money..
if u can afford it..and not feel bad for the amount spent...you should go for it!
