Vikramdeals
Hi All,
I need your help to upgrade from my 2.0 set up to 5.1.2 Atmos set up.
My current set up includes :
Please can you help and recommend:
Note: Below three images are of same room however, since, all the dimensions were not visible in single image, I ended up taking three screenshots if it helps any way.
- Marantz SR 5014
- Tannoy Mercury V4i Floor Standers
- Buy a sub of good quality and leave the rest of the set up (centre, surround and Atmos (2)) for later as budget is limited and can be a constraint Or
- If possible, in the budget mentioned above, if I can get entire 3.1.2 set up
- Which of the solution options stated above will be good to go and why?
- Additionally if you can recommend speaker systems and sub within the budget stated above?
- Would satellite speakers or Wireless speakers be good for the living room set up to avoid too much wiring and if possible within the budget above?
- Also, I read somewhere, that it is advisable to have a 5.2.2 set up vs 5.1.2. Any thoughts on that with the above budget constraint
