Upnp connectivity issue with jiofiber router.
josedandrew
Trivandrum
I have been using bubbleupnp for streaming tidal to allo digione running moode.
Recently changed to jiofiber connection, and now the moode renderer no longer shows up in bubbleupnp app.
Going to moode configuration and restarting the upnp renderer brings it back on, but it needs to done everytime the streamer is powered up.
I tried volumio, that too shows the same issue.
Issue seems to be with the router.
Currently using jio jcow401 router.
Previous router was GX platinum 4410.
Any pointers what could be causing the issue? Thanks.
Allo connected via ethernet cable.
No issue with range in general. Distance to router from seating position is 3m only.
Can you try using wifi? Jio routers don't provide proper handshake to RPI based devices what I have noticed, I had to connect other router to jio router in order to get first install of RPI OS. Jio couldn't detect it at all.
Thanks. Will enable wifi and try.
So, what you are saying is.. the rpi should be connected to router through wifi also, in addition to existing Ethernet connection.
As of now the rpi is only connected via Ethernet. But as soon as it boots up I am able to access moode via browser and everything including Spotify connect works like a charm, except that bubbleupnp can't see it in the network.
Only one connection, Wifi or Ethernet.
Also try installing a fresh firmware maybe if nothing works.
I experienced the same thing. With both volumio and moode on mconnect my rpi upnp renderer very often just disappears. I need to either restart the renderer from the GUI or restart the Pi from mains power. Did anyone have any luck to resolve this?
