URC 7960 remote issue
gman
chennai, India
Hi all,
I am trying to use OneForAll URC 7960.
There are 6 toggle options at the top (tv, stb, dvd, amp, mp3, media). However it is only toggling between the first 3 and never goes to the rest of them.
I need to map this remote to my amp as well.
Has anyone found similar issues? any workaround?
63 views and 0 responses!
Anyway, it turned out to be an issue with batteries. When replaced with new ones it started working fine. Just posting this so others might benefit in case they run in to similar issues... cheers.
