TheSeeker
Hello all,
coming from here - http://www.hifivision.com/home-theater/64943-pls-suggest-bit-old-model-htib-newbie.html
finally I seem to have homed in on a couple of models. decided to create this separate thread to attract more suggestions specific to this query.
first things first. I need the AVR for movies + music (a 60:40 usage ratio roughly). I don't have speakers for it, other than a pair of FS which I use only for music, and plan to continue doing so. so will have to buy separate satellites & sub. that'll come at a later stage. first focusing only on AVR. room-size would be around 10-12ft long & ~8ft wide. its basically our hall, doubling up as HT-space. so...
1. on one hand I have the option of a Yamaha RX-V581, about 2 months old, being offered for 34k.....reviews look very good, plus, its future-ready WRT dolby atmos & dts:x....downside/catch is, the seller (an individual) is insisting that if I demo it I have to buy it. am a newbie and haven't properly auditioned AVRs before. the RD store near my home was useless in this regard. plan to go to a couple of AV stores near my home today (including 'soundtech'). hopefully they have this particular model for demo.
2. the other option is a Marantz NR-1605....some members have suggested me to go for this over the 581....however, to me, its reviews didn't seem very confidence-inducing....and its not future-ready as well....though presently I don't have atmos speakers, but I hope to buy some up-firing speakers sometime in the future......this piece am getting is 3 months old, for 43k.....the seller, suggested me to take the demo of the Yamaha one first, and then Marantz, and that then I'd 'forget' Yamaha altogether! am not sure here.
dear members, pls suggest which one would be better....or atleast, pls suggest a few stores where I could audition both.....things would have been easier had the Yamaha seller agreed to give a demo without imposing the condition of ought-to-buy with it......but now I will have to go hunting for demo at some store, provided its available anywhere......
here're a couple of reviews I had went through
on v581 - Yamaha RX-V581 review | What Hi-Fi? (big bass and details look enticing!)
Yamaha RX-V581 REVIEW - Feature Rich and Good Sounding
on nr1605 - Marantz NR 1605 REVIEW | Short Stature-Big Sound
https://www.cnet.com/uk/products/marantz-nr1605/review/
TIA!
P.S. - the third one, nr-1606, although having already overshot my budget once, is one I can still consider. am told that 1605 & 1606 are virtually identical except for the atmos & the tad high power of the latter.
requesting attention of @murlidher saar too
TIA!
