Used Psb Image T5 speakers for 50k worth ?
umesh k
Jaipur
Hi friends need some advice on upgradin my speakers.
I came across this guy who is sellin this used Psb 5.1 speakers for 50000 rs. are they worth buying for this sum. Please help...
Thanks a lot
The T5 are floorstanders. Which do you mean, the T5 or it is a 5.1 set of which speakers?
Hi thanks for the reply. Its a set of two floorstanding towers, one front, two surrounds and a subwoofer... sorry I dont have much knowledge but I ve been told this 5.1 speaker setup is called Psb image T5.. please advise. ?.
Thanks a lot
If the condition is good and there are no damages to the units and the sound is clean from the setup , just buy it. 50k for all 5.1 setup is no where close to reality. :)
t5 is the model no for the floorstanders. the rears and centre will have different model nos. as long as its the t5's with similar model centre, rears and sub, and its in good condition go for it. new would cost 1.5lakh atleast
i agree, as long as its the t5's with similar model centre, rears and sub, and its in good condition go for it. new would cost 1.5lakh at least
