Used subs... advisable?
ShaQ.Blogs
I have a pair of floorstanding speakers. I was wondering if it is a good idea to look out for a used subwoofer. If yes, does anyone know where I can get one from?
any suggestions or advice is most welcome.
If I go for a new sub what would be a decent buy? My towers are PSB T6.
What would this Subwoofer be used for i.e Movies or Music? and whats the size of the Room?
Listen to both both...50-50. Should I go for one good sub or 2 average?
As of now...14x12. Will build a bigger room in a year or two...14x20 maybe.
What is an ideal budget I to compliment my PSB T6?
With T6 ideal match is PSB Subseries 300 but now since your requirement is 50% of both Music and Movies then please do audition PSB HD8 which is a sealed subwoofer and also very powerful. But its a fantastic subwoofer for Music as well as Movies. Both the above models retails around 55K.
55K for a sub...well
thats much beyond my budget...i was looking for within 30 ish K. For 30Kish would I find a good sub???
For that price (55K), I think I should be able to get hold of SVS SB12 or HSU VTF-3. Which I heard are really good subs.
