Used Technics SL1200s India
dchaitanyarao
Hyderabad
Hey guys where can I buy a 1/2(if sold in a pair) Technics SL1200/GR used in India ? I live in Hyderabad as of now. Any leads would be helpful.
PS: I did find similar threads but they were way too old.
And
Technics SL-1300 Automatic and Manual durable turntable.
Type Direct drive full auto player
Turntable 33 cm Aluminum Die-cast, 1.65 kg
Motor Ultra-low speed electronic commutator motor
Number of revolutions 33 1/3, 45 rpm
Rotational speed fine adjustment range Adjustment Range 10%, Each Rotation Speed Independently Adjustable
Wow and flutter 0.03%(W.R.M.S.)
Signal-to-noise ratio 60dB(IEC-B)
70dB(DIN45539B)
Tone arm Universal S-shaped Pipe Arm
Needle pressure direct reading type
Static balance type
Gimbal suspension system
Anti-skating force control device
With Oil Dump Type Queuing
Needle pressure adjustment range 0 ~ 3g, Direct Reading Variable
Applicable Cartridge Weight 4.0g ~ 8.5g
8.5g ~ 13g (When Using Auxiliary Weight)
Pwer 100 VAC, 50Hz/60Hz
Power consumption 4W
External dimensions Width 453x Height 139x Depth 366 mm
Weight 9.4kg
https://www.olx.in/item/turntable-t...-listing-coming-within-20-days-iid-1746926664
